Previewing Documents in the Hover Panel
About the Hover Panel Component
The Hover Panel component lets users quickly view a document preview when they hover through their SmartHub query results. If Smart Previews is installed, the document preview is shown in the panel. Otherwise, the panel displays the document metadata.
How to Configure Your Hover Panel
Before continuing, familiarize yourself with the information in the topic How to Use the UI Editor.
UI Editor
The easiest and fastest way to insert and customize the HoverPanel feature is via the SmartHub UI Editor.
For more information, see How to Use the UI Editor.
SmartHub administrators can simply click the UI Editor link from the SmartHub Administration page.
Select (double-click) an HTML page such as Results.html page.
BA Insight recommends you use page and folder to modify. Leave the default files as templates.
For example: Customizations/Results.html. Default Results.html is under the top most SmartHub directory.
Select the Advanced mode from the top right of the page.
Select Advanced settings edit.
Scroll down to line 216 (this may vary), which contains the text
SH.HoverPanel.CustomSettings
Click the Default Settings. A new browser tab opens with all available SmartHub module settings.
- Search for the word "HoverPanel" on the page to quickly navigate to the HoverPanel default settings, shown below:
- Copy the HoverPanel settings section from SH.HoverPanel.DefaultSettings.
- Go back to your Advanced settings edit tab.
- Paste the copied settings inside section SH.HoverPanel.CustomSettings.
EnableHoverPanel
value is set to "false" by default. -
Modify settings as desired. See the "Hover Panel Settings" table below.
Click Save changes.
Click the link Preview <html> file.html at the top of the code editor.
Review your HTML page in the new tab that opens.
Make any necessary changes back in the code editor. Repeat steps 14-18 as necessary.
Click Save changes.
SH.HoverPanel = SH.HoverPanel || {};
SH.HoverPanel.DefaultSettings = {
EnableHoverPanel: false,
EnableHoverPanelForCBS: false,
DisplayPreview: true,
TemplatePath: SH.RootLevelURL + "/modules/HoverPanel/templates/template.html",
ContentTemplatePath: SH.RootLevelURL + "/modules/HoverPanel/templates/defaultContent.html",
CorrectionLeft: 0,
CorrectionTop: 0,
HoverSelector: ".sh-result-item", // For TabularView use ".k-master-row"; For CoveoResults use ".CoveoResult"; For ContentContainers use ".sh-result-item"
CloseHoverPanelWhenHoverOver: ".coveo-header-zone,.header-info,.footer-zone,.sidebar",
ViewButtonLabel: "View".toLocaleString(),
ViewButtonTooltip: "Open in viewer".toLocaleString(),
AddPageButtonLabel: "Add page to workspace".toLocaleString(),
AddPageButtonTooltip: "Add this page to workspace".toLocaleString(),
AddDocumentButtonLabel: "Add document to workspace".toLocaleString(),
AddDocumentButtonTooltip: "Add full document to workspace".toLocaleString(),
DelayTime: 300
Settings Example
SH.HoverPanel.CustomSettings = {
EnableHoverPanel: "true"};
SH.HoverPanel.PathsToExclude =[];
Setting Name | Default Value | Description |
EnableHoverPanel | false |
EnableHoverPanelForCBS | false |
DisplayPreview | true |
TemplatePath | /modules/HoverPanel/templates/template.html |
ContentTemplatePath | /modules/HoverPanel/templates/defaultContent.html |
CorrectionLeft | 0 |
CorrectionTop | 0 |
HoverSelector | .CoveoResult |
CloseHoverPanelWhenHoverOver | .coveo-header-zone,.header-info,.footer-zone,.sidebar | A list of class selectors that, when hovering over the elements with one of the specified class, the hover panel will automatically close |
ViewButtonLabel | View | The label of the "View" button. |
ViewButtonTooltip | Open in viewer |
AddPageButtonLabel | Add page to workspace | The label of the "Add page to workspace" button . |
AddPageButtonTooltip | Add this page to workspace |
AddDocumentButtonLabel | Add document to workspace | The label of the "Add document to workspace" button. |
AddDocumentButtonTooltip | Add full document to workspace |
DelayTime | 300 | Number of milliseconds that you have to hover over an item in order for hover panel to be displayed. |
How to Show Different Metadata in Your Hover Panel
The default template can be found in the directory \modules\HoverPanel\templates\defaultContent.html.
- In order to customize the metadata shown, create a new HTML file in your customizations folder, and copy the content of defaultContent.html in it.
Modify the new template adding the following snippet for every metadata property that you want to show:
<div class="hp-content-property">
<div class="hp-content-subtitle">
Custom metadata title
</div>
<div class="hp-content-property-value">
<%= resultItem.CustomMetadata %>
</div>
</div>Example of Custom Template
<div id="<%= 'hp-metadata-container_' + elementId %>">
Contributors include
</div>
<%= resultItem.DisplayAuthor %>
</div>
</div>
Last modified
</div>
<%= new Date(resultItem.LastModifiedTime).toLocaleDateString() %>
</div>
</div>
</div>
</div>
</div>
</div> -
Change the ContentTemplatePath setting to the path of the new custom template.
EnableHoverPanel: "true",
ContentTemplatePath: "/modules/customizations/HoverPanel/templates/customContent.html"};
How to Disable the Hover Panel Component
To disable your Hover Panel, use the following instructions:
- Follow steps 1-6 in How to Configure Your Hover Panel.
Change the EnableHoverPanel value to "false".
EnableHoverPanel: "false"};
SH.HoverPanel.PathsToExclude =[]; - Click Save changes.
